multicolumn list box selection of Complete Row
Hi guys ,
I want to know that is there a way to select a complete Row from MultiColum List Box Or Table on  the Front Penal  and then paste on the next row. Its kinda same as microsoft Excel when you select a complete row and coloum and then paste it back to any other row or column and all the values are pasted. The program i am working on requires me to write bunch of values all together in the multi column list box and then copy the same values with jsut a little change(maybe in just one column) and then write them again ..
Regards
(4,913 Views)
Its just array manipulation if I understand your question right.
Something like this:multicolumn listbox.png
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(4,909 Views)
Can you send me the VI of it , that would be grate , But what I am trying to achive is that to use the front panel , but I already found out an easier way is to use Microsoft Excet or Open Office Calc with LabView.
Regards
(4,884 Views)
Accepted by topic author nolsqn
Hi
Right click on your multi column listbox. Under Selection mode, select Highlight entire row
Under Drag adn Drop, select allow dragging and allow dropping.
Run your vi, select a row, hold control button and drag the row to the next column.
attached vi is in LV2010. Run the vi in continuous mode and try what i said
however, i have not tried this with tree.
Regards
Freelance_LV
TestAutomation Consultant
(4,879 Views)
