multicolumn listbox changing value in sub-vi
The multicolumn listbox is not updated (refreshed) when changing the value with property node via reference handle.
(2,428 Views)
The problem is that the value property sets the value of the multicolumn listbox (which BTW is an I32). To set the value of the cells in the listbox you have to use the itemnames property (which is a 2D array of strings).
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,428 Views)
