multicolumn listbox pull-down menu
please i need to insert data in each element of a multicolumn listbox. each data inserted come from a pull-down menu.
My question: is there a way to transform each element of a muticolumn listbox to a pull-down menu ?
if not, how could i assign the data selected from a menu to an element in the multicolumn listbox ?
Thx,
Samer,
Message 1 of 8
(7,611 Views)
You have to program this yourself.
See, for example: http://forums.ni.com/ni/board/message?board.id=170&message.id=277721
Message 2 of 8
(7,606 Views)
I didit in my last project, look here:
http://forums.lavag.org/Table-with-Drop-Down-Items-t11249.html
Regards, Eugen
Message 3 of 8
(7,602 Views)
I created the VI but when i click on the multicolumn list (column N°2) the ComboBox is always invisible, i tried but it is not working...
Could u help me ?
Samer,
Message 4 of 8
(7,556 Views)
You have 2 problems:
  • The combobox's Z-order is that it's in the back. You need to move it to the front. Select the table, and select the "Move To Back" command from the Z-order button in the toolbar.
  • The "Tableau" array is initially empty. When you perform a Replace Array Subset you're trying to replace an element in an empty array. Result: empty array.
Other issues:
  • You need an event case for the "Stop" button. The way it's coded now, clicking the "Stop" button will not stop the VI until another event occurs, which in your case is that someone clicks in the second column.,
  • You have a few extra unnecessary property nodes. See attached picture.
  • You can use the error cluster to enforce data dependency, and therefore execution order, eliminating the need for the sequence structure, which is extraneous. See second attached picture.
  • "<Empty>" is not one of the valid strings in the combobox, so this test will never work.
Message 5 of 8
(7,538 Views)
Thx for your help...it is working now Smiley Wink
Samer,
Message 6 of 8
(7,523 Views)
I tried to insert data in a multicolumn listbox but i didn't succeed...i tried 2 methods but in vain...
Could u tell me where is the problem in this simple VI ?
Samer,
Samer,
Message 7 of 8
(7,509 Views)
Hi samer,
to insert data you have to write that data to your table...
Message 8 of 8
(7,494 Views)
