Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
multicolumn listbox
multicolumn listbox
tonitpp
Active Participant
08-05-2005
03:56 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a little problem. I would need to know if the user has selected some item of the multicolumn listbox, that is, If there is an item selected in the multicolumn listbox. I have use the value property but it doesn't work.
Some ideas?
ToNi.
0
Kudos
Message
1
of 2
(2,858 Views)
Reply
Re: multicolumn listbox
eriasystemes
Active Participant
08-05-2005
08:06 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi, I do not understand why you had problems in getting the item selected in a multicolumn listbox.
Here is a little example on how it works. Your problem could be that if the lines do not exist you cannot select them...
Hope this helps !
Julien
Multicolumn ListBox.vi 41 KB
0
Kudos
Message
2
of 2
(2,843 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
