multicolumn
Please would appreciate any guidance on how to input a Pass/Fail in the 'Status' column of multiply which is dependent on my output.
Message 1 of 14
(5,944 Views)
Message 2 of 14
(5,929 Views)
Its a continuation. 🙂
Using a different approach and not sure if I could continue on the previous thread hence a new one
Sorry if its an inconvenience
Message 3 of 14
(5,923 Views)
Still looking forward to some sort of help.
Message 4 of 14
(5,852 Views)
It looks like that thread answered all of your questions and posted some very useful code.  What part of using it are you having troubles with?
Also please come up with some more descriptive titles.
  • Have a useful title.  The title of your question should never be "labview" for "fpga".  Your title should also not be a paragraph.  It should be a quick summary of the topics your post is going to discuss.
https://decibel.ni.com/content/docs/DOC-40451
Message 5 of 14
(5,836 Views)
Thanks. I'm trying a different approach and can't seem to be able to get the pass/fail comment to display in the last column 'status' using this new approach.
Don't knw if this makes sense
Message 6 of 14
(5,794 Views)
It doesn't.  Post code of the new method if the old one doesn't fit your needs.
Message 7 of 14
(5,775 Views)
Already did. Thats the attachment at the start of the post.
Want to input a Pass/Fail after the output column which is dependent on the result of the output.
sort of started on the 'multiplication'
Message 8 of 14
(5,770 Views)
You are already using the insert into array function to insert the whole third column (index 2) so do the same for your status column using the insert into array with column index set to 3, and provide an array of strings which has an item of Pass or Fail for each row.
Message 9 of 14
(5,758 Views)
thanks.
I'm a bit lost though
"and provide an array of strings which has an item of Pass or Fail for each row"
what do you mean by this?
Message 10 of 14
(5,751 Views)
