multimeter x in multisim
when i run a circuit in multisim and what to watch the results through a multimeter what are the settings for the resistance, ampere, and voltage. espcially for the internal resistance because it seems like im not getting the correct readings because it is not programed correctly. thank you for your help
(3,978 Views)
You'll have better luck if you post your question in the Circuit Design Suite (Multisim, Ultiboard) forum.
(Be sure to properly capitalize your message to make it easier to read.)
(3,967 Views)
Hi Afaro,
When you expand the multi-meter, there is a "set" button; click on it and you will see the multi-meter internal resistance.
Tien P.
(3,936 Views)
