multiple Format Specifier Syntax
I have a simple question but complicated to me for a long time.
When I manipulate a string, I added some special characters like space, tab or other.
However, I want to know the skill in case of many special letter.
For example, 5 tabs requires \t\t\t\t\t but cannot be intuitive.
Do you know any other skill like 5(\t)?
labmaster.
(3,813 Views)
Hi Labmaster,
You have a string with some characters and you want to add 5 TAB characters: you need to add those 5 TABs. What other "skill" do you expect?
What's not "intuitive" to type 5 TABs when you need them?
(3,790 Views)
In many cases, I felt some difficulties to count the number of special characters.
I wondered how other people can treat this.
labmaster.
(3,771 Views)
Hi Labmaster,
I never had the need to include 5 consecutive TABs in a text file…
You have some weird formatting going on!
But you could:
- use a FOR loop to generate your TABs 🙂
- use an array of 6 empty strings, followed by ArrayToSpreadsheetString to generate 5 TABs… 😄
- use a ConcatString with 5 inputs and wire a TAB constant to each of them…
(3,764 Views)
