multiple IP camera
Hi
Im designing a control system and I now want implement multiple cameras to surveill the system.
Whats the best type of cameras to use? I've tried with some simple webcams, but then its only possible to stream from one camera at the time.
Im now considering Axis 206 network camera. Does anyone know if its possible to stream for multiple IPcameras at the same time?
Or what about firewirecameras?
Its a lowbudget project so I dont need pro cameras... 😛
Thanks in advance
Bjornar
(4,110 Views)
Well, Axis makes cameras for the low budget. You may want to look into the bullet cameras and 4 channel web servers. Just a basic overview, they are great quality optics joined with good electronics utilizing BNC analog signal to BNC on the video server. The video server then coverts it to Data TX/RX for use in a plug and play UNP that is easily detected by your network. It will show up under my network. Yes you can stream multiple channels. In fact Axis software comes with it that has multiple arrays 1/2/4/6/8/10 on and on. I use both the analog bullets cams by Axis and the PTZ 213 networked and love all of them.
Good luck and let me know how this turns out. If time permits, I may have a surplus cam/serv lying around some where. 🙂
Torn_Victor!very-happy smiley
(4,059 Views)
Contact sthaler@imagination-engines.com , we have a VI that will let you access multiple cameras simultaneously in labview.  We currently support the Axis 210A, 241S 241Q, and most USB cameras and video capture boards.  We can add additional cameras upon request if they are compatible with our specification..
The views expressed by myself are not necessarily those of Imagination Engines, Inc. LLC
www.imagination-engines.com
(3,992 Views)
