multiple array data to table display
to start there is one 15 bit array that is separated into three 5 bit arrays.  there are 5 boolean buttons that if selected,  it will give the value of the three 5 bit arrays for that index.
example
if 15 bit array is equal to:
111110000011111
then 5 bit array equals:
11111 array 1
00000 array 2
11111 array 3
if boolean index 0 and 2 are selected the the bits selected are bolded
11111 array 1
00000 array 2
11111 array 3
the output is a 1 d array looking like this:
110011
the for loop took three iterations to do this operation and my question is that is there a way to put this data into a table that has the loop iteration in one column and the values for that interation in the next column.  looking like this
sample    |    value
    0          |      11
    1          |      00
    2          |      11
Attached is the vi that gets to the output array
(3,508 Views)
I whipped this up real quick, so it's not perfect, but I think it'll get you what you're looking for.
(3,499 Views)
thank you very much
(3,493 Views)
