multiple channels on graph
Hi, I am trying to display 2 2-D arrays on 1 graph. I found many examples on the forums that seemed to be what I was looking for, but I just cannot get it to work.
Can anyone maybe make a example (LV 7.0) of displaying 2 2-D arrays one one graph?
Thanks a lot!
Ryan
Ryan
LV 7.1
(3,197 Views)
Could you explain why each channel is a 2D array? What is in the second dimension? What kind of graph are you trying to use (Waveform, xy graph, etc.)
It would be easiest if you could attach a simplified version of what you got so far. Put the two arrays into diagram constants before saving and let us know what kind of graph you want.
(3,193 Views)
I guess I should clarify.
It really doesnt have to be 2 2-d arrays now that I looked at it more.
It will be an array (n=15) and a constant. I would like the array of 15 elements to be a bar graph. The constant needs to create a horizontal line (a "threshold") so that the user can see if the bars are above the line.
I hope this helps...I will try and post something soon.
Ryan
LV 7.1
(3,187 Views)
Here is a simple example of what I want to do...I don't think it should be difficult, I am just not figuring it out.
Thanks for the help.
Ryan
LV 7.1
(3,185 Views)
(3,183 Views)
Yes that is exactly what I was looking for. I missed the initialize array...
Thanks again Dennis and altenbach
Message Edited by esa_paranoid on 06-03-2005 01:01 PM
Ryan
LV 7.1
(3,181 Views)
Here's an even simpler way 🙂
Message Edited by altenbach on 06-03-2005 11:57 AM
(3,177 Views)
