multiple chart memory
I have to acquire 32 signals and display it on 5 differents waveform chart with a sample rate of 100kHz. My problem is when I use 1 waveform my program works, but when I have more one waveform chart, my RAM increase continousily until I have an error of overwritten.
All my chart history lengh is 1024.
Could you help me please?
Thank you very much
Romaric GIBERT
Message 1 of 11
(5,085 Views)
It sounds like you may be building an array inside a loop. Can you post the code?
Richard
Message 2 of 11
(5,081 Views)
Here is my VI
Thank you very much
Message 3 of 11
(5,079 Views)
I don't have 2011 installed yet. I'd advise saving down to 2010 so more people can access the VI. Smiley Happy
Richard
Message 4 of 11
(5,071 Views)
I haven t the VI in version 2010 in  my home. I did some screen shot
Thank you very much
Romaric GIBERT
Message 5 of 11
(5,068 Views)
But you can File... Save for A Previous Version.
That will make a new folder and put the VI's in it.
Richard
Message 6 of 11
(5,058 Views)
Sorry I didn t know this option.
Here is my vi in labview 2010
Message 7 of 11
(5,053 Views)
Those blue wires duplicate data.
Mod your code to use the Waveform data type (using index array to select and build array to assemble) and the memory foot print should be smaller. Not ideal but smaller.
Moving the chart updates to the consumer loop would also let you avoid the "buffer duplication on wire branch" where you split the wire to update the graph and pump the queue.
Ben
Message 8 of 11
(5,044 Views)
Thank you very much for your response.
If I well understood, you would like that I change the blue wire by array. Is a llike in my picture  attachment file ? Can I wire directly the output of my build array to the waveform chart?
Thank you very much
Romaric GIBERT
Message 9 of 11
(5,037 Views)
I tested with your advice, change the blue wire by array but it s always the same things.
Any idea??
Thank you very much for your help
Romaric GIBERT
Message 10 of 11
(5,022 Views)
