multiple charts using daq assistant
I'm using the SCXI and I'm trying to read values from thermocouples as well as voltage values from heat sensors.
I can create charts to display the data for each of these, however I'm having trouble acquiring data from both the thermocouples and the heat sensors at the same time. Only one or the other aquires data.
Does anyone know how to make it so both acquire data at the same time?
I'm using the DAQ assistant.
Thanks.
(2,688 Views)
Hello sunny dee,
You can open up the DAQ Assistant and just click on the button that looks like a piece of paper (next to the red "X") above the channel list. This will allow you to add other channels to the current task. Make sure you have the DAQ 7.4 driver, otherwise I believe that it will only let you add channels of the same type. The link to the DAQ 7.4 driver can be found here:
http://digital.ni.com/softlib.nsf/websearch/90B60D5899BCCCDB86256FC700581B89?opendocument&node=132050_US
Take care,
E.Lee
Eric
DE For Life!
(2,667 Views)
