multiple counter in ni usb 6341
hi
i m working on DAQ usb 6341 and facing a problem. when i use two frequency counter in the same program it stops calculating frequency (frequency counter task hangs). but when i use only one frequency counter it works properly.how can i solve my problem..................?
Message 1 of 11
(4,578 Views)
Hey nadeem,
I need to know a bit more about your setup to better help you with this issue. What version of LabVIEW are you running? Also, if you could either include your code or a screenshot of your code, that would be great. Thanks!
~kgarrett
District Sales Engineer
Message 2 of 11
(4,568 Views)
hi i m using labview 2009. i have two fuel flow sensers with frequency output. i want to measure the fuel flow.
The problem which i am facing is that when i use single sensor it works fine.But when i use two frwquency inputs from ni usb 6341 it hangs or not works properly.
Message 3 of 11
(4,558 Views)
Hi nadeemalikpda,
Without seeing your code, I am still not sure what could be going on, though it is unlikely that the counter itself is hanging (unless you are trying to read faster than the specified read rate for the card). If you open LabVIEW and click Help » Find Examples » Hardware Input and Output » DAQmx » Digital Frequency » Meas Dig Frequency-Buffered Cont-High Freq 2 Ctr.vi, two instances of this code should work for your desired function. If you still have issues, please post back. Thanks!
~kgarrett
Message 4 of 11
(4,550 Views)
ok thanks 4 ur reply i will upload my code..................
Message 5 of 11
(4,542 Views)
hi this is my code
plz reply me early
regards
nadeem
Message 6 of 11
(4,525 Views)
Hey,
I have a couple of questions for you. I have down loaded he VI and and trying to reproduce your error. Is there a particular error message associated with the "hanging" of LabVIEW? What type of sensor are you using?
Perry S.
Message 7 of 11
(4,512 Views)
no there is no error messege.
i am using two MPU sensors.
There are two high speed inputs as you can see in the program VI.
when one MPU stops the other reading of other Mpu sensor also stops even it is working.
means these two MPU sensors have to work toghter. if any one of the input stops other,s reading in the
program VI also hangs .
Message 8 of 11
(4,506 Views)
Hi nadeemalikpda,
I'm getting a little confused here.  What do you mean when you say that one of the MPU's stops?  Are you trying to stop one from reading and let the other tasks continue?  If you will need to place each DAQ Assistant in a different loop.
Have a great day,
Chris
Message 9 of 11
(4,499 Views)
i mean to say that i have two motors with two Encoders on them. when one motor stops . the reading of other encoder also stops (HANGS).
Message 10 of 11
(4,494 Views)
