multiple file reading and 3d graph
Hi
I build this vi to read in multiple .txt files and plot them all in a 3d graph. Problem is only the last loaded file is plotted, and not all of them in "angle of reflection" (y-axis) continuously.
Message 1 of 9
(3,957 Views)
sorry, double post, can some admin delete one of them?
thanks
Robert
Message 2 of 9
(3,950 Views)
Your 'Load Data' vi is only reading in the first of the files. You must do something like the attached to read in all of the files.
Randall Pursley
Message 3 of 9
(3,948 Views)
if i use a for-loop, the data-stream will be 3d but all rows only accepts 2d?
Message 4 of 9
(3,940 Views)
I changed numerical to array, but i still have this type-error 2d <-> 3d with the graph and the write I/O ?
Message 5 of 9
(3,936 Views)
does somebody know how I can get a 3d array ionto a 3d graph without loosing information?
Message 6 of 9
(3,919 Views)
Ok, now I get them all presented one after the other, but I would like to have each new one at a new y-coordinate, any hints?
Message 7 of 9
(3,915 Views)
can you post two or three files, which you would like to read?
I am testing your program but i have problems with the files.
Regards
Markus Weigl
NI
Message 8 of 9
(3,896 Views)
Markus,
Make sure to check the other thread here where I think I addressed Robert's question and advised him to avoid creating duplicate threads for a single issue.
Best Regards,
John
Message 9 of 9
(3,881 Views)
