multiple graphs but want one scrollbar
i have three xy graphs, with x being time and y being a waveform. on 2 of the graphs, i have 4 plots each and 1 plot on the third (9 plots total). i want to be able to scroll all three plots with one scrollbar so i can compare all plots for the same time. also is there a way to control the xmin and xmax scale for all three graphs by a user input? thanks alot
(3,892 Views)
Look at the attached VI
Used property nodes of 2 graphs to make them respond to a common x scroll bar
Hope this helps
Regards
Dev
(3,875 Views)
Hope this helps
Regards
Dev
(3,876 Views)
If you have LabVIEW 8.0, you can use Mixed Signal Graphs that would offer you common scrolling and many other advantages.
New in LabVIEW 8: Mixed Signal Graph
Ankita
(3,865 Views)
One more cool feature in 8.0 Smiley Wink
useful one!
(3,847 Views)
