multiple graphs in XYgraph!
Hi guys!
I have a litle problem. I am using a program, to draw several curves in a only one xygraph, I have a while loop, i read from the file (spreadsheet file), each file take 2 curves (4 arrays). I want to open differents files into the graph, but when i draw one file, with i try to open other the graph is cleared and draw only the new file.
This option is for draw differents curves to compare them.
How can I do it for see several curves?.
Thanks, i would be grateful to you...! (if it possible with a example i could to see better)
(3,444 Views)
I have attached a vi which adds a new curve to xy graph without clearing the previous graph.
Change x & Y array values & press Add button to add the curve to xy graph.
Hope this works. If your problem is not solved, pl. write. Your feedbacks are welcome.
Best Regards,
Nirmal Sharma
INdia
(3,444 Views)
