multiple individual data points
I am slowly learning Labview and need help on a VI.
Application: I want to take calibrate a displacement laser taking one data point at 30 different dispalcements.
I would like to input the displacement (mm- 0 to 30 mm) before taking the data point.
I would like to dosplay them side by side.
Example:   0 mm         0 volts ;           3mm        ? volts ;      15mm         ? volts
(4,208 Views)
Great.  So what are you having problems with?
This sounds like a simple state machine with an event structure for allowing the user to enter a distance and then allow the user to take the measurement.  I would display the results in a table.
(4,195 Views)
You correctly understand the need. The problem I am having is that I have not understood a way to do this. I looked on line for tutorials but non appeared to provide a way to do it. Would you have an example?
(4,162 Views)
Start by breaking down your problem into much smaller problems.  These will be the states you will need to create.  Start with allowing the user to enter a value.  Then make a state for reading the measurement.  Then make a state for building up your table.
When the problem is broken down like this, it suddenly becomes a lot easier.
(4,148 Views)
Hi terry_LETU,
In this link you'll find a video on how to create an Event Driven state machine, so you can get started with your project as crossrulz adviced.
LabVIEW Tips&Tricks Episode 3: Event driven state machine - YouTube
https://www.youtube.com/watch?v=RuIN31rSO2k
Carolina
(4,120 Views)
