multiple input OR gates
If I want to OR three items, do I need to use two separate OR gates with the output of one as an input to the second (along with the third item).  Or is there an expanding gate that I haven't found yet (like the expanding array inputs, etc).
(20,500 Views)
You are looking for the compond arithmatic function.  In LabVIEW 8.0 its under the numeric pallette and the Boolean pallette.
You can expand it out to have multiple inputs and then you can change its mode to OR, AND, and XOR.
(20,493 Views)
That's exactly what I needed.
I love this forum!!!!
It's probably too much to hope for, but coming from some XILINX design, I have to ask...
Is there a way to invert individual inputs going into a gate?
Thanks a bunch.
(20,490 Views)
Right click on the input and select invert :)
(20,484 Views)
Thanks again.
Looks like I am going to have to right-click before asking questions. 🙂
(20,474 Views)
