multiple loops with event structures
Why can't I get the event to execute?
Thanks.
Message 1 of 11
(4,386 Views)
Do you have a 50" monitor or something?
Your code makes no sense in terms of trying to understand what you're attempting to accomplish, but the event executes just fine.
Message 2 of 11
(4,377 Views)
I start the vi and hit Startx number (0-1) starts to update. Hitting Ready to start 2 and start 2 does not start number 2 or 3 on my machine.
Message 3 of 11
(4,368 Views)
Attached with smaller windows.
Message 4 of 11
(4,367 Views)
It's all in the dataflow. Once you are running in the inner loop, the rest of the code cannot continue until the inner loop stops again. It is not a good idea to trap the code inside an inner loop.
Please tell us how your program is supposed to be used and how it should react to the user inputs.
Message 5 of 11
(4,365 Views)
number 1 represents motors that have to be started before data is taken; numbers3 is other steps to be carried out before actually taking the data number2. Once the data is taken the motors, (number 1) need to be stopped.
Message 6 of 11
(4,358 Views)
In that case, I would strongly suggest using a different design paradigm, such as a state machine. Your implementation is confusing and prone to errors (as you've already experienced), not to mention difficult to change.
Message 7 of 11
(4,355 Views)
I looked up a state machine. There seems to be a lack of documentation. This seems to be the extent of it.
Standard State Machine—Use this template to build a standard state machine design pattern. Each state executes code and determines which state to transition to. Contrast this design pattern with the user interface event pattern, in which code executes in response to user actions. Contrast this design pattern also with the queued message handler pattern, in which each message handling code can queue any number of messages.
The code needs to execute user actions as well as a portion in the example
Message 8 of 11
(4,341 Views)
State Machines are used in all types of Design, Software and Hardware (FPGA's ASIC's etc).  Would probably be worth looking outside of the LabVIEW community for a more general Introduction to them.  There are different variations on them too (Moore / Mealy / Queed).  However i have found them an Invaluable tool in Engineering and they are not too difficult to get your head round.
Craig
btw i have no idea how to spell Quee'd !
LabVIEW 2012
Message 9 of 11
(4,335 Views)
State Machines are fundamental to good LabVIEW development.  Here is a LabVIEW tutorial that might help you get started.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
Message 10 of 11
(4,285 Views)
