multiple peakfinder in 1D array
Hi i am Thijs Boeree and i'm working on a data analysis program, i have an
1-D array in a graph and want to find multiple peaks, when you move the
cursor over the graph it has to work as a magnet so that it stick to peaks.
Has anyone ever programmed something like this?
Best regards Thijs Boeree
(3,795 Views)
Hi Thijs,
you can use a Peak Detector.vi from Analyse>Signal Processing >Time
Domain.
See attached file. This program demonstrate how to use this vi.
Best Regards
Mike Manzheliy
(3,795 Views)
Here is another example, written in LabVIEW 5. It shows a way to locate each peak in the graph with the cursor. Use the "Next" and "Previous" buttons to locate the peaks. The attachment include a text file called "EKG.txt" that you can use for testing.
The attachment is a .zip file.
Best regards;
Enrique
www.vartortech.com
(3,795 Views)
