multiple plot in Labview with 2 analog signals
Regarding this problem, I am having the same one too. I am using Labview 10 and im very new to this software.
I have 2 analog signals , so how do i use the multiple plot / multiple graphs functions in Labview, so that when i move the cursor on the chart, itwill give me both values from my 2 signals.
Hope i expressed my question right.
Thanks in advanced
(3,529 Views)
If you are using chart for multiple plot then you can just right click on the chart
go to Visible items>>Digital display. Select it and you can see values of both signals...
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,521 Views)
Thanks for the fast reply. I'll try to do it with your solution given and will give a feedback. 🙂
(3,511 Views)
