multiple pulse counters
hello,
we have a usb-6210 daq system, and we would like to measure 4 different pulses from 4 different flowmeters.
We already looked at the edge count option but there are only 2 counters inside the device.
is it possible to measure all 4 the sensors a once??
Luuk
(2,677 Views)
Can you bring the data into the DAQ from the flowmeters on an analog input? If so, you have plenty of analog inputs. Once the DAQ has acquired each waveform you could use software to look for pulses and then count how many pulses you see.
Does that help?
(2,654 Views)
