multiple sample rate
Hello all,
I have a several NI PCI-4472 cards into a computer, and I would like to know if it is possible
to set different sample rates for each card, without loosing the possibility to do a synchronized
acquisition with all the cards.
I recently discovered this forum and I found it is really great, many thanks for your answers !
Olivier
(2,684 Views)
Yes you can set multiple cards to different sample rates. And yes again, you can trigger them all off the same signal--check into the RTSI bus. It might be helpful for this...
Whoo, Whoo! Two for two!
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,679 Views)
