multiple scales do not assign properly ot traces
The Labview XY Graph object does not allow me to map signals properly to their scales.  I have attached a simple XY Graph VI where there are 3 input traces that I want to map to their 3 respective Y Scales.  The drop down menu item does not allow me to map to any scale except for Y Scale 1.  ANy body know why this is?
(2,854 Views)
Hi id,
I tried this vi in 8.0.1 and found the same issue. You can change the mapping from the front panel Plot Legend, but not on the Properties > Plots > Y- Scale drop-down-menu. The same is true in 8.2, but in 8.5 you can do it (I know that probably doesn't help much).
I'm including a version of your vi that sets different scale values for the Y scales.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,835 Views)
I am not sure which drop down menu you are talking about.
But would this attachment help?
Message Edited by Vsh on 11-17-2009 05:47 AM
(2,833 Views)
Iam using LV8.6 and this problem is not found.  What i suggest is intialize the graph with number of plots that you wish to plot once.  then you go for that menu it will show the actual number of YScales.
If not the menu will reflect only one plot.
Post back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,824 Views)
