‎02-14-2007 05:10 AM
‎02-15-2007 05:25 PM
‎02-19-2007 06:40 AM
‎02-20-2007
03:41 PM
- last edited on
‎10-07-2026
08:15 AM
by
Content Cleaner
Hello Jon,
You should be able to perform the operation you described by exporting the pattern match trigger in your acquisition session to start your generation session. The example program "Dynamic Generation and Acquisition-Source Synchronous.vi" demonstrates this process. For more information about this example you can check out this [link removed; article no longer available] document on our website. You would need to change the trigger type on the acquisition to Pattern Match Start Trigger, but this example should give you a good place to start. I hope this information is helpful, let me know if you have any other questions.
