multiple temporary variables in a formula node
I am able to create formula nodes with multiple inputs and a single expression
in the "box". But for several complicated expressions involving sqrt() and
trig functions, I want to use a formula node with multiple inputs, a single
output, and several (3 to 4) temporary variables within the formula node. Can
this be done?
An example (not actual code) of my expression in the node box is shown below.
A --> | double dval1, dval2, dval3; |
| |--> D
B --> | dval1 = sin( A*A - B ); |
| dval2 = cos( sqrt( A*B ) - B*B ); |
C --> | dval3 = atan( 23 + C*C ); |
| D = dval1 + dval2*dval2 - dval3; |
Why does this approach generate errors?
Mike
(4,547 Views)
Change the "Double" to "Float" and it should work. The formula node apparently does not distinguish between different floating point data types.
It took me a while to find this out. The help file should have this information in it but doesn`t.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(4,547 Views)
Answer found (I think) !
On my PC, in my "LabVIEW" directories, there is a header file called,
fundtypes.h. I saw that the C type, double, had been typedef-ed to float64.
I tried using float64 to declare "double" variables in my formula nodes and
they worked fine. There are other C variable types that have been typedef-ed
here, as well.
> types.
> Shane
Mike
(4,547 Views)
