multiple timer+saving to file
Sorry, let me start over:
I was browsing old threads and I found a VI to create a timer. Please see "before.vi" However, I didn't want it to output onto an indicator, instead, I wanted to output the total time onto a file, and I changed it to "after.vi".
However, that change doesn't work. Could you guys advise on what I should do to get it to work as I want it to? I think I can figure out the cascading thing in the OP after that.
Message 11 of 17
(2,245 Views)
See comments above
Message 12 of 17
(2,240 Views)
How would I get the values to "save" over to the stop event?
Message 13 of 17
(2,238 Views)
Accepted by topic author johndoe3344
wire them
Message 14 of 17
(2,235 Views)
Got it!! Thanks!!!!
Message 15 of 17
(2,233 Views)
Those tunnels set to use default if value if unwired can be a pain in the neck sometimes.  Smiley Very Happy
I've found its a good practice to use them sparingly and only for states that really don't matter.  Glad to help!
Message 16 of 17
(2,230 Views)
I knew my comment would be proven true eventually! Use default value takes down another!
Message 17 of 17
(2,225 Views)
