multiple waveform charts
Just a general conceptual question:
I want to generate multiple waveform charts,
The amount of charts can be variable....
I want them all laid out on the same panel at the end of the running of the program
What is the best way to do this, multiple VI's, clone VI etc.?
thank you
(1,618 Views)
Hi LED,
In LabVIEW you cannot create new indidcators at runtime, you have to create/define them at edit time.
So you should create the amount of needed indicators in your VI(s)!
Note: you can hide indicators at runtime when you don't need to show them on your UI…
(1,610 Views)
excellent answer thank you!
(1,607 Views)
