multiple window in the same VI
hi
i want to display multple window in the same VI
how to create liste of buton  where each button displays a vi or show another displayes like config and test
thanks for help
(3,048 Views)
Hi dalyto,
play with tab controls or with subpanel containers…
(3,028 Views)
SubVI's can show their own front panel when called, which opens in a separate window.  This allows you to have things like a config window popup when you click the config button, while still being part of the same application.
(3,014 Views)
