multiple windows encapsulation
thanks guys, i'll check it out
Message 11 of 13
(1,334 Views)
Hi lavalava,
have you come to a solution so far?
I would really like to know if you solved it?!
Greetings Smiley Surprised
Message 12 of 13
(1,190 Views)
I've been using the GToolbox for the last few years to do exactly this. You can find it at http://webspace.webring.com/people/og/gtoolbox/.
It is reasonable priced and works pretty well, however you will need to get a new (free) installer every time you move up to a new LabVIEW version, and the new versions of the GToolbox usually lag quite a bit from the LabVIEW upgrades. The website still says "Available for LabVIEW 8.6, 8.5, 8.2, 8.0.1, 7.1, 7, 6.1, & 6", where even LabVIEW 2010 is old news.
Although I have to say that George, the creator, is very helpful and will send you some VIs if you must upgrade your LabVIEW version and need a few GToolbox VIs updated. I've tried this once.
Hope this helps!
Message 13 of 13
(1,013 Views)
