multiplicate by is own each element of a vector
Hello!
I have a vector and i want to multiplicate each element by his own. For example:
a=[2 4 6]  i want to obtain  b=[4 16 36]
I don't want to use for loops.....I've searched some block in matrix menu but I couldn't find the good solution.
What i have to do to obtain this result as a operation between matrix without using a a for loop. There is some block to make this operation?
Thanks in adavance
Michael
(2,395 Views)
Hi Michael
This is what you are looking for.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,390 Views)
hi
Just go ahead and multiply the array wit itself as shown in the attached VI
it will give the desired result
regards
Dev
(2,384 Views)
