multiplying array elements with their indexes
How can I multiply array elements with their index values.
Thanks in advance.
Message 1 of 10
(6,323 Views)
Accepted by topic author aksoy
Hi aksoy,
multiply the elements with their index:
Message 2 of 10
(6,322 Views)
A slightly modified version
Message 3 of 10
(6,315 Views)
Thanks GerdW,
Now I have two arrays. One contains the measurement values and the other has the time for each point. How can I combine these two to have dynamic data with time. Therefore I can filter, graph or write data to a file with time values.
Aksoy
Message 4 of 10
(6,307 Views)
Hi aksoy,
when your data samples are evenly spaced in time you could use a waveform.
But as a generic answer to your generic question I would tend to "stick with your two arrays"!
- You can easily plot them using an XY graph.
- You can easily save them using WriteToSpreadsheetFile.
- You can easily filter them depening on your time array.
- You can easily attach new samples to each array.
Message 5 of 10
(6,302 Views)
You can use the build waveform function to achieve this.
Message 6 of 10
(6,299 Views)
Thanks All,
How can I convert double 2D array to waveform to generate a waveform with time values?
Message 7 of 10
(6,288 Views)
Hi aksoy,
you can't (easily) convert from 2D array to waveform.
As I mentioned before: when your samples are evenly spaced in time you might convert to a waveform: A waveform consists of start time t0, sample time dt and sample values Y. No need for an additional array with time values here...
If this doesn't apply: stick with two arrays!
Message 8 of 10
(6,284 Views)
Dear GerdW,
I think more or less my problem is clear. I have 2D array with data values. I need it with time values attached to it. Therefore I can play on it easily. Thus I am a new bei in labview. Any suggestions is wellcome.
Best Regards,
Aksoy
Message 9 of 10
(6,278 Views)
Hi Aksoy,
given your description I can't give other suggestions as I already did...
Message 10 of 10
(6,275 Views)
