multipule cases choosen by boolean buttons?
How can i choose multipule cases for one case and only one for another case? FOr the one case i am using the build array function along with the search 1-D array function which works great. But when i want to choose multipule cases at once using the same 4 boolean buttons as when i choose only one case, I can't get more than one button to work. I get the zero case to work but not cases 1,2,3. i tried using individual build arrays and search 1-d arrays, but that doesn't work either. I would appreciate your help, thanx!
(2,599 Views)
If I understand your question correctly, you might want to try using the Boolean Array to Number function then take the results of that to the case statement. You can have a separate case for each number, or you can have a case that handles different numbers (i.e. 2,3).
(2,599 Views)
With the boolean array function, how would I use it with 4 booleans and 4 cases because the boolean that i'm using only gives a 1 or 0?
(2,599 Views)
You use the build array with the four Booleans like you were doing before but instead of the search array function, use the Boolean Array to Number.
(2,599 Views)
