multisim -labview
when i connect multisim and labview using connectivity toolkit i get following error"Error -2147467259 occurred at Unspecified error  in Multisim Connect.vi->Quick Demo.vi  Possible reason(s):  LabVIEW:  (Hex 0x80004005) Unspecified error."
(3,147 Views)
do you you have Power Pro version of Multisim? Did you check the log (probably in C:\Documents and Settings\<your username>\Local Settings\Temp)?
http://www.ni.com/multisim/compare.htm
Zenon Kuder
Applications Engineering
(3,037 Views)
