multithreading RS232 labview
Hi every body,
I have to develop an application that execute 16 threads in which I communicate with 16  device via RS232 . I use a Multi port card NI8430/16.
Is that possible with labview. Can it work in parallel. I have no idea about multithreading. Can you give me an example. the pc, need it any special configuration.
Thank you for help it is very urgent
Message 1 of 10
(5,827 Views)
Can't you just create 16 of these and then read and write from each?
Message 2 of 10
(5,814 Views)
LabVIEW is definitely capable of multithreading.  All of the threading is handled internally in LabVIEW.  I think that PRCalDude's recommendation is a good one.
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
Message 3 of 10
(5,777 Views)
I think this vi (visa serial) is not re-entrant. Hence you would not gain much with creating sixteen. I would check into the actual lower level VISA functions and see if those are re-entrant. Otherwise all the threads would be just waiting for the other to finish.
Message 4 of 10
(5,759 Views)
Oskar is definitely right.  The visa serial is not re-entrant by default.  The following KnowledgeBase addresses this issue:
Accessing Serial Ports Using Parallel Execution Hangs My Program Intermittently in LabVIEW
http://digital.ni.com/public.nsf/allkb/59458684CF7861CC862565410061DB3B?OpenDocument
Nick Keel
Message 5 of 10
(5,749 Views)
Correct, the VISA configure VI is not reentrant.  But so what?  That VI should only be called once per port at the beginning of the code.  And it would not take long to run anyway.
You don't even need to use that VI.  It is just a wrapper for setting a bunch of property nodes for the serial port.
Message Edited by Ravens Fan on 05-29-2009 04:51 PM
Message 6 of 10
(5,748 Views)
Hmmmm.... I can definitely see myself running into that problem in the future.  Thanks.
Message 7 of 10
(5,738 Views)
Reentrancy is not even relevant. That KB article that Nick posted was written in 1997when there were separate serial functions. Now, all serial functions are VISA. The article on synchronous/asychronous would be more relevant to this discussion.
Message Edited by Dennis Knutson on 05-29-2009 03:13 PM
Message 8 of 10
(5,727 Views)
Good article regarding the synchronous versus asynchronous. Seems useful for everyone to read.
Message 9 of 10
(5,691 Views)
Thanks for all!
Message 10 of 10
(5,672 Views)
