mutex switch
Hi
 Now I have a problem, I want to achieve a mutex switch, how can I achieve it? The function of the switch is follow:
Switch1 and switch2, when the value of them is turned to true from false, all of them will be controlled by themselves.
But when the value of each is turned to false from true, the value of switch1 depends on the value of switch2, if the value of switch2 is true, the value of switch1 is false, else is true, the same to switch2.
Best wishes
vivian
(2,688 Views)
I would consider putting these two switches into an event structure.  Perhaps the Mouse Down? event.  You could read the value of the switches.  If one or the other is true, and the switch with the mouse down event is currently false, you could discard the event to prevent it from going true.
See attached.
(2,665 Views)
