mutiple pulse modulation
Hi James-
Glad to help- let us know if this doesn't work out for you.
Thanks-
Tom W
Message 11 of 22
(2,649 Views)
I tried the VI and didn't see what I hoped. I didnt see the digital state turn high until I set the logic threshold to -6 (-5.279 after playing around with it more). Originally I had it set to 0. I am sending +5VDC and the level never changes.
 I am using dev1/ai0. I have pin 67 connected to gnd (the AI gnd) and I also have pine AI sense connected to gnd. I also tried it with and without apfi 0 connected to gnd. Do know why I see this?
Thanks again Tom,
James
Message 12 of 22
(2,639 Views)
Hi James-
Let me make sure we are using the same connections:  you should have the positive terminal of your source wired to pin 68 (ai0 input) and the negative terminal of your source wired to pin 67 (AIGND).  I noticed that I did not specify the RSE terminal configuration directly in my earlier post, so I have modified the VI to force it to use RSE terminal configuration.
When you wire a DC source I would not expect any change in the indicator; you will need to test with a source that slowly oscillates above and below the logic level to see any change on the indicator.  Let me know if you're not able to see better results-
Tom W
Message 13 of 22
(2,631 Views)
Tom,
Thank you for taking the time toshow me how to do that. I didn't have time to look at it too much, all I did was test it against 5 and 0 VDC and that worked. I'll test it against a clock signal and see how fast it can record the data.
Happy Holidays,
James
Message 14 of 22
(2,626 Views)
Hi James-
That sounds promising- let us know if you're still running into problems.
Tom W
Message 15 of 22
(2,614 Views)
Hi James!
Did you acomplish your aims with the programme? Seems like I´m having almost the same problem, although in my case I only have to control 4 digital Outs so that I don´t need the analog INs...
Would you mind sharing your knowledge with me? The problem is that I´m almost a complete Labview-Starter and don´t know that much about digital signal processing.
Thank you in advance,
Alex
Message 16 of 22
(2,558 Views)
Alex,
I did accomplish what I set out to do. I don't quite understand what you are trying to do though. What DAQ card do you have, as I understand they are all different. I needed 8 timers, my card only had 2 so I used different hardware to achieve my goal. Let me know what exactly you are trying to do and I might have a suggestion. If you only have to control 4 digital outputs that program should be very very easy....
Best of luck
James
Message 17 of 22
(2,549 Views)
Hi James,
I have got an PCI 6254 and the aim is to generate 4 (better: 6) digital rectangular signals with pulse width modulation. That is, it should be possible to adjust frequency, duty-cycle and time seperation between these signals for each one. I think that task may not be that difficult, but I´m new in LabView and DAQ so I need some hints or an example. I would be pleased if you could send me a copy or part of your progamm in order to try it out on my system.
Thank you,
Alex
Message 18 of 22
(2,534 Views)
Alex,
I looked at the data sheet for your card and it says that you only have two counter timers. If you have the option to purchase a card with more counter timers I would recommend that. If not then you could use software to compute your PWM signal, but this is not a good way to accomplish what you are trying to do if accuracy is an issue. What I did was I found an IC (LMD18245) that created a PWM based on an RC pair and a binary number. What exactly are you using the PWM signal for?? Keep searching the net and using the Labview software. Good luck, hope this helps.
James
Message 19 of 22
(2,518 Views)
Hello James,
The best way to generate digital pulse trains for PWM applications is using the counters on your DAQ device.  Alex is right when he states that your PCI-6254 device has two counters on the card, so you are limited to generating two simultaneous pulse trains with this device.  If you are looking for a device with more counters, National Instruments sells dedicated counter/timer devices that contain up to 8 counters per card.  Take a look at this comparison chart to see the different channel counts and specifications for the counter/timer series devices.
You can use the same program to implement PWM using the DAQmx driver with your PCI-6254 M Series device or with one of the counter/timer devices.  Here is an example program that shows how to change the pulse specs of your pulse train on the fly in terms of duty cycle and frequency.  I hope this helps!
Travis G.
Applications Engineering
Message 20 of 22
(2,500 Views)
