my SignalExpress launches then shuts down with an error
I have not used the labview in a while and now when I boot my computer I get an nidevmon.exe application failed to initialize properly.  Then when I launch signalviewexpress it starts then fails with an error
"COULD NOT START THE APPLICATION PLEASE CONTACT NATIONAL INSTRUMENTS"
(2,745 Views)
Hi A&A_B,
There are several possible reasons for the nidevmon.exe error.  I first suggest trying some of the solutions outlined in the KnowledgeBase article:  Application Error nidevmon.exe in Traditional DAQ or DAQmx
If you end up at step G (uninstalling the drivers), I would recommend using the MSIBlast utility when uninstalling.  This will clear any remaining driver installation files from your PC.   Keep me posted on your progress.
Best Regards
Hani R.
(2,729 Views)
