my VISA READ isn't reading
Hi - I have a super simple vi setup where I have a VISA write (I write to a motor to turn forward using 0xC7 ) and I can see the motor turn. Wired next to it, is the VISA read because the controller that I am communicating to is supposed to return the hex code : AA 55 but I get a time-out every time.
What is happening?
In Codevision AVR I can send the hex command in a terminal and I get the AA 55 back, as expected. What could the difference be ? We don't use any termination characters btw.
Thanks!
Message 1 of 15
(4,007 Views)
You should use the Bytes At Port function prior to reading. Could be that you are reading before the bytes are there. Put Bytes At Port into a while loop and exit only when the number of bytes is greater than zero, then wire the number of bytes to the Read function's Number of Bytes to Read input. If this don't work, send a sample of your code.
- tbob
Inventor of the WORM Global
Message 2 of 15
(4,002 Views)
i did this but it didn't change a thing. please see attached vi........
Message 3 of 15
(3,996 Views)
NEVERMIND - my bad, it DID work. Do I have to have it in the while loop though? Thanks!
Message 4 of 15
(3,995 Views)
See attached vi for the proper solution. While loop is necessary to wait until bytes have arrived.
- tbob
Message 5 of 15
(3,991 Views)
oops i only have labview 7.0
can you please revert?
Message 6 of 15
(3,979 Views)
Here it is:
- tbob
Message 7 of 15
(3,975 Views)
it's a beautiful thing...thanks....
but now my return bytes from visa read are just the command that i sent to visa write. for example if i send C7 i should get back AA55 but instead i just get the C7 back.
did we change something because i was reading hex AA55 yesterday?
Message 8 of 15
(3,964 Views)
I don't see anything in the vi that would cause that. You must actually be getting those characters back from your device. You can use hyperterminal to verify this. If hyperterminal gives you something different, then you need to investigate the vi. However, the vi is simple and straightforward and I can't see anything wrong with it except that you should put a VISA Close at the end (please do this, I forgot to include it). Perhaps the device on the other end needs initialization or something to get it started.
- tbob
Message 9 of 15
(3,962 Views)
the only thing is that i don't know how to type in hex code into the hyperterminal or any other type of VISA session like Instrument I/O Assistant express vi. my co-worker did the Codevision AVR stuff. do you know how to specifiy that what i am typing is hex?
thanks!
Message 10 of 15
(3,953 Views)
