my program doesn't graph
That sentence makes no sense. No one, including altenbach (note correct spelling) asked for your audio samples and I don't think anyone cares. And I for one, do not know what a random corridantes generator is.
It also does not sound like you bothered to try my suggestion.
Message 11 of 49
(2,669 Views)
It's called a joke.
I guess some people don't get LabVIEW jokes.  I can't help it -- sarcasm is my native tongue.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 12 of 49
(2,660 Views)
I tried your suggestion dennis and it still doesnt work
Message 13 of 49
(2,648 Views)
Are you still getting the error? I ran the program with my hardware and N Samples and did not get an error.
I also just noticed you are using a mixed signal graph instead of an XY Graph. I've not used the mixed signal graph that much so I don't know if that is the cause of your display problem.
Message 14 of 49
(2,636 Views)
I didn't get the errors anymore but I meant it didn't graph anything for me though. Did it graph for u?
Message 15 of 49
(2,631 Views)
/sigh at resolutions above 1280x1024
Message 16 of 49
(2,629 Views)
wut u mean brent?
Message 17 of 49
(2,626 Views)
Initially, I only tested for no errors with the data acquisition. I just now reran it and did not see it graph. I probed the x and y inputs and noticed that you are passing a constant into the Y input. In fact, it was always 0. I have no idea what you are trying to do with the Y scale but code outside the while loop will only run once.
Message 18 of 49
(2,604 Views)
The y scale should be changing everytime depending on the time. If you notice the time elapsed is getting multiplied by 1.52 and that would be the y value. I'm getting a value for y everytime
Message 19 of 49
(2,580 Views)
You CANNOT use run continuous mode. As I mentioned to you before, this is to used only for special debug circumstances. Please pay attention to advice being given.
Message 20 of 49
(2,575 Views)
