my vi was working but now isn't. Why?
I am using Visa to control a serial device using rs232.  After some bugs, we were finally able to talk to the instrument and get data back.  I tried adding a control which did not work, so I went back to the oringial configuration.  I can no longer communicate with the instrument.  Everything is the same as it was when it was working.  I was getting timeout errors at Visa Read, and now it looks like its timing out at the very beginning.  We've cycled the instrument and closed and reopened the vi.  I'm wondering if we need to flush buffer (using the vi), but I can't figure out how to get it to work.  Any suggestions?
(2,858 Views)
nevermind, problem solved.
(2,845 Views)
Please fill us in on what you figured out the problem was.  That kind of information can help others in the future if they search the forum looking for the answer to the same problem.Smiley Wink
(2,820 Views)
when I recreated the constant for visa write, I forgot to check " \ " so that it recognized the \ as a command and not just a slash.
(2,788 Views)
