myRIO FPGA - Working code suddenly uses 300% LUT when compiled
I had a working FPGA vi. I created a backup of the vi and continued development. After some time I tried compiling the new vi and wasted a day trying to find out what caused the sudden 300% LUT usage.
Just now I tried to recompile the backed up (unchanged) vi only to find out it has the same 300% usage (I dont know how much LUT it used before but it must have been <75%).
So, what on earth magically took all the LUT, where do I start looking? Must be something thats not in the vi?
Is there a quicker way to get a rough ressource estimate without the 20min wait?
(3,890 Views)
Once compilation is complete, the Compiler Status window gives you access to the Xilinx Log under Reports. If you haven't already looked at it, I would check it out. It will tell you LUT usage of individual things. The report can be daunting, but look for an item that uses a ton of LUTs.
Another way to go about it is compare your old code to new code. What changed?
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,869 Views)
Before we start: I cleaned up my project a little (removed VIs that arent even in the vi Im compiling) and recompiled - it magically worked. Even the original VI where the problem started (before I started to shrink it again) compiled. I have nooo idea what happened there.
XilinxLog.txt showed some things that seemed suspicious to me. First there were many
INFO: [Synth 8-3969] The signal iRAM_reg was recognized as a RAM template for dedicated block RAM(s) but is better mapped onto distributed LUT RAM for the following reason(s): The *depth (4 address bits)* is shallow.
Later there is:
WARNING: [Synth 8-3323] Resources of type BRAM have been overutilized. Used = 157, Available = 120. Use report_utilization command for details.
And many:
WARNING: [Synth 8-3463] Infeasible ramstyle = block set for RAM DualPortRAMx/InferredRamx/iRAM_reg,trying to implement using LUTRAM
But I dont know, that log is a lot to read. I attached the file so you can have a look at it, I cant get anything helpful out of it...
(3,851 Views)
