myRIO_unrecoverable error message in getting started wizard
I wanted to find the firmware in myRIO. Therefore
1. I connected the myrio using USB to my computer.
2. chose launch the getting started wizard, clicked next
3. I get this unrecoverable error message (please see image 1)
Ni-Max gives an unexpected internal warning (image 2) and then it says there was a problem connecting to the database.(image 3)
may I know how can I fix this issue?
(2,639 Views)
(2,606 Views)
Hi Garena,
I did reset the configuration data, but it did not help
(2,602 Views)
Have you check if you installed the minimun required software for working on myRIO?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7btSAC
(2,594 Views)
