myRio-1900 Varying Analogue Output Voltage
I'm looking to connect a DC motor to the +/-10V AGND AO pins on a myRio-1900 and want to control/vary its speed at different times.
My question is, can I vary the output voltages from these pins via programming on the myRio within the range of 0 to +/-10V, or are they always stuck at exactly +/-10V?
Cheers, Tyler.
(2,614 Views)
Hi Tyler,
a ±10V AO can take any value between -10V and +10V…
(I hope you don't connect the motor directly to that AO pin, but use an external amplifier board.)
(2,531 Views)
