02-22-2023 11:03 AM
Hi Everyone,
I am trying to open a project that interfaces with a myRio. I've installed the myRio Toolkit and all drivers, but I still get a missing driver message. Everything is 2021 btw. I'm a novice at LabVIEW, so I really appreciate all the help.
02-22-2023 11:23 AM
Did you try running the "NI License Manager" program to see if everything you installed has been licensed?
02-22-2023 11:49 AM
Hello, Songkang. Welcome to the LabVIEW Forum.
I have installed myRIO Toolkits since shortly after the myRIO was released, and the 2021 Toolkit is, by far, the most difficult to install. I was fortunate to be able to discuss this Toolkit with some of the NI Developers who explained the "correct" way to install this software, and I have posted my experiences in the "Additional NI Products Boards", under "Academic Hardware Products, myDAQ and myRIO" .
It would help me to help you, and other students getting started with LabVIEW and NI's Academic Products (such as the myRIO) if you could provide me with some additional information about yourself and your myRIO.
Bob Schor
02-22-2023 03:27 PM
Hey Bob, appreciate the detailed help. I'll try to answer all the questions one by one.
1. Yes, I'm a student using this for an independent study project
2. I'm borrowing the myRio
3. no, I just googled it and downloaded everything from NI
4. I just downloaded LabVIEW and put my school license in
5. I downloaded LabVIEW first, then downloaded the real-time and DAQ modules, and recently did the myRio toolkit
6. See screenshot of MAX below
Thanks again for the help,
Song
02-22-2023 03:28 PM
Just checked, LabVIEW is actively running with my school license.
02-22-2023 07:52 PM
Good news! You should be able to install LabVIEW 2019 (or 2019 SP1), and the myRIO Software Toolkit 2019. This is a fairly straight-forward installation with fewer problems than the more recent 2021 version.
One important consideration is that the myRIO Software Toolkit has pretty stringent requirements. It will not work "optimally" with any version of LabVIEW except LabVIEW 2019. I also recommend that you use 32-bit LabVIEW (that's the version that I've been using for the last 15 years, with no significant problems).
Here are (most of) the steps to install LabVIEW 2019 and the myRIO Software Toolkit 2019. The phrase "most of" is because I'm doing this from memory, though in the past year or two I've done a dozen of these installations. I often do a "pure" installation, (safely) removing all NI software first, but since it appears that all of your NI software is older than LabVIEW 2019, let's try just install the "new stuff" and leave the old code alone. If this doesn't work, I'll show you how to do a safe removal, and then a "pure" install.
Installation of LabVIEW (in my experience) works best when done "slowly", installing only a few elements at a time with multiple reboots. I assume you have access to a decent Network connection, as we'll be connecting to NI's download site for this installation. You will need your Academic License to activate LabVIEW and Toolkits as we install them.
Please let me know if/how this is going. I'd appreciate another screen shot of MAX's Software listing. Try to widen the Software window so I can see things more clearly.
Bob Schor
02-27-2023 01:51 PM
Hi Bob,
I tried everything you said, and I'm running into a strange issue. I removed everything 2021 and installed 2019, but I'm only seeing LabVIEW 2018 now? I'm not really sure how to approach this. I've attached screenshots of what I'm seeing below.
02-27-2023 07:17 PM
I think there is a way forward. Five days ago, I sent you a Private Message through the LabVIEW Forum, but I'm guessing you haven't seen it. I'm going to send you a second message in about 5 mintues.
When you sign in to the Forum, you should see your Profile name and avator in the upper right part of the screen. There should be an image of an Envelope (suggesting a letter, or message) with a number beside it (the number of messages you haven't read). Please read my message -- if you can't see any messages, you can respond here in the Forum saying "I can't see your messages" and I'll see what I can do.
Bob Schor
02-28-2023 09:52 AM
Hey Bob,
Didn't realize you'd sent me a message, I'll check it out.
