mySql and bigint ID
When fetching data from a MySQL table using a simple SQL query "select * from" all of the data is returned properly except for the ID column. The ID column is a primary key set to auto incremental, bigint type.
Labview returns no values. Is there some limitation. Thanks.
LV2012, MySQL 5.2
(2,766 Views)
If you're using VIs from the Database palette in Connectivity, you should return variant data from the database. For a column whose datatype is bigint, Variant to Data wired with a numeric constant set to I64 should work.
CLA
(2,684 Views)
Thanks. That works.
(2,674 Views)
