myrio Data logging
I used the accelerometer code provided in myrio project essentials guide to read the values from accelerometer. I need to store these values atleast for 10minutes but i'm facing trouble doing that. I herror.PNGave tried using "write to measurement file" function as mentioned in the 1st attachment below and got this error :
I have also tried using "write to spreadsheet file" function as mentioned in the 2nd attachment below but it was a failure too.
(4,893 Views)
Hi Lonewolf27,
As you are trying to store quite a bit of data, I would recommend streaming this data from your myRIO to your host PC. This can be done with a DMA FIFO - there's lots of links online that will help you with that. On the Windows side of things you can store to a TDMS file.
If you want to keep everything on the RT:
Looking at your code, I don't thing the write to file functions you have used are supported on the RT. Try using the lower level functions or the TDMS file functions.
(4,736 Views)
Please keep in mind that this code is running ON the myRIO.  It is NOT ON YOUR PC.  Therefore, you cannot arbitrarily have your myRIO write to a file on your PC.  What you need to do is use a Network Stream to send the data to an application on your PC and then that application can save the data to a file on your PC.
(4,731 Views)
No.  A DMA FIFO is for sending data to/from the FPGA.  In the case of the myRIO, that is a direct connection between the RT and the FPGA.  Besides, the OP is not even programming in the FPGA.  A Network Stream is the proper tool here to send the data to the PC.
(4,727 Views)
Thank you for clarifying, I had a total brain fart there!
(4,718 Views)
