myrio camera issue
can anyone help me about this error.camera working perfect when i connect with only my pc but when i connect with myrio and then communicate with myrio over wifi then it give following error
imaqdx  0xBFFF8004
am using
  1. Labview 2014
  2. Myrio 1900
  3. vision acqusition 2014
  4. labview realtime module 2014
(3,195 Views)
Hi there!
What software do you have installed on the MyRIO? To use your camera with the MyRIO, you need to make sure to install IMAQdx. It also looks like the camera you are using is a USB 2.0 camera that is UVC compliant. When you install software on the MyRIO, make sure to also install USB Webcam Support.
-Jordan
(3,157 Views)
Thanks for your kind reply i upgrade the all software related to myrio 2014 to 2017.but it's still not worked.again same error ocurred.
(3,152 Views)
Have you tried formatting the MyRIO?
-Jordan
(3,149 Views)
yes. i tried 5,6 times.
(3,143 Views)
