myrio
great salutation for all
i have  a problem that i would love to get answer or an issue to solve it ...THANKS IN ADVANCE
during few days ago i recieved my board Myrio under a student licenced package, i installed all the necessary i mean both DVDs myrio bundle that were in the package ...i did what i have to do (i mean connections, .......) i even started the model existing for the gyroscop and the FPGA module, it works perfectly...
my problem started when i wanna start my own project i think the time i over the library it should appears something like''myrio> analog in , analog out ......."
but this doesn't appear to me. even during the first connection and the initialization process the board doesn't recognize the LABVIEW and gives me "" Real time could not be foun"" i did the update , but this doesn't solve anything.
 I hope i was clear on what i'm searching for .!!?
what should i do to get the blocks of the inputs and outputs of the board on the VI model !?
and what should i do about the FPGA module that the board doesn't find it!?
(3,496 Views)
Accepted by topic author zoldaioque
Hi there,
So every time that you connect the myRIO to your computer are you able to see the NI myRIO USB monitor?
If so, when you go to MAX and expand the Remote Systems are you able to see your device?
If you are, I would suggest that you have already installed all the modules and drivers for your myRIO, like LabVIEW Real Time module, FPGA module, NI RIO, NI Compact RIO and myRIO toolkit, all those modules and drivers must be the same LabVIEW version that you have installed in your computer.
So if you do see your device on MAX, if you select it and click “System settings” Tab, you will see the IP address of it (we may need that number). After that if we open LabVIEW>>create a project>> right click on “Project:Untitled Project#”>>new>>Target and devices.
A new windows is going to pop up and you will find two option under “Existing target or device”. The first one is called “Discover an existing target or device” if you select that you must open or expand “myRIO” folder and you should see your device there.
If you are not able to see it, please select the second option “Specify a target or device by IP address” >> there you must write the IP address of your device (you can see it on MAX)
Then select OK and you will see your device with all the I/O on it
Regards
(3,450 Views)
