mysql without odbc call library function node
hy!
i'm trying to send a SELECT query to a mysqlserver by calling the needed functions in libmysql.dll
i get a successful connection and can read the server-version, but the result of the query which should be something like DATETIME|INT|INT and so on is quite a mess:
“À›ÀŸÀ2012-02-13 08:40:46
I read in the documentation of fetch_lenght, that this function should recieve an array, but how can i tell a Call llibrary function node to return a array?
MySQL_fetch_lengths
libmysql.dll  i used: mysql-connector-c-noinstall-6.0.2-win32.zip
(6,168 Views)
Is there a reason you are going about this the hard way with the dll instead of the database connectivity toolkit or any one of a number of free options for using standard SQL? I doubt that you will find many (if any at all), that have tried your approach.
(6,142 Views)
I used the DBToolkit in the first way but it should be a executable wich can be used without installing  any other software (ODBC e.g.). I also tried the solution from SAPHIR but this one is extremly slow with large querys. It should also work as 32 and 64 bit executable
I read something about using the Call library function node with LabVIEW instad of a DLL but i can't geht it working.
https://decibel.ni.com/content/docs/DOC-9091
(6,134 Views)
So instead of installing the small odbc driver, you would rather install the dll? And, you would need to support both 32 and 64 bit dll's. Sorry, I can't help.
(6,129 Views)
How to read a function return pointer that is an array, can be seen here. Kind of messy I know, but interfacing C is a mess in comparison to LabVIEW programming.
For the rest I think I fully agree with Dennis. Lots of sweat and work for a questionable benefit. And your strange data probably comes from binary and text data being mixed in the returned pointer based on the column datatype. Good luck with creating a LabVIEW VI library that can handle that transparently.
Rolf Kalbermatter  My Blog
(6,118 Views)
One possibility could be to open a TCP connection to mysql and send queries / commands via that.
I did this with some success many years ago. Unfortunately I no longer have access to the code.
It'll still be considerably more work than using odbc though.
Good luck!
(6,104 Views)
did you make it work?
what was the result?
Can you share your final VI?
Thank you.
(5,634 Views)
